3.8L V6 Stroker ?
jeepxj3
Vehicle Model: xj
3.8L V6 Stroker ?
Post by jeepxj3 »
This site is mostly about the inline 4.0L based strokers, but a JeepStroker is a JeepStroker.
Having said that, the 3.8L V6 found in the '07-'11 JKs are getting old and these JKs are getting cheaper. Most are high mileage and soon will be requiring a new rebuilt engine.
So what is available for this 3.8L?
505 has/had a kit. Questionable shop reliability and engine build quality.
http://www.jeepforum.com/forum/f96/rebu ... l-3047209/
I'm thinking a mild stroker build similar to what is being done to the 4.0s.
-Crank- stroker or offset ground
-Rods- upgraded, need to work with chosen crank
-Pistons- custom forged, tighter quench, slightly higher compression
-Cam- mild replacement hydraulic roller
-Heads- rebuilt, ported, big valve, mild valve springs for valve train reliability
-Headers- short or long tube
-Viper Throttle Body
-Tune- SCT or Diablo
Any ideas or thoughts?
jeepxj3
Vehicle Model: xj
Re: 3.8L V6 Stroker ?
Post by jeepxj3 »
Stock 3.8L specs
bore- 3.780"
stroke- 3.430"
CID = 230.5
cc = 3778cc
intake valves- 48mm 1.890"
exhaust valves- 35.5mm 1.398"
jeepxj3 wrote:This site is mostly about the inline 4.0L based strokers, but a JeepStroker is a JeepStroker.
Here's the Hesco stroker kit for the JK 3.8.
http://www.hesco.us/products/7550/strok ... f-NWd-qpBc
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
I thought that that Hesco kit was unavailable.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Brianj5600 and 1 guest
