What readings should I be getting with my stroker 6 on my OEM Wideband gauge? Ideal? Max? Minimum?
I am running Accel 24# injectors a BBK 70mm throttle body and a Comp 4x4 Extreme cam.
Stroker 4.6 Wideband Air/Fuel Values?
Burnsmacdonald
- Learning to use the board
- Vehicle Model: TJ
Re: Stroker 4.6 Wideband Air/Fuel Values?
14.7:1 in closed loop/ cruise and most around town driving. 13.5-12.8:1 under heavy accel and WOT.
Burnsmacdonald
- Vehicle Model: TJ
Those are close to the values I am getting static (ie in the driveway) between idle and 3000rpm
This weekend I will take it out and see what it does on the road under real load
Get back to you with the results.
Idle should be 14.7:1.. Reving it while not moving shows nothing useful.
Burnsmacdonald
- Vehicle Model: TJ
agreed.
Thats why I need to take it out for a run through the gears.
Burnsmacdonald
- Vehicle Model: TJ
Took it out for a test run today and ran it through the gears.
At full throttle it is between 13.1 and 13.4
When cruising at 2500 rpm it is in the very low 14's
- Vehicle Make: Jeep XJ
Ideally the AFR should be slightly richer (12.5-13.2) at WOT and leaner (14.7-15.4) at cruise. You numbers are OK for performance but cruising fuel economy will be less than what it could be. This is where a custom PCM tune can make a difference.Burnsmacdonald wrote:Took it out for a test run today and ran it through the gears.
- Stroker Displacement: 4.9
Owe you a call. hang tight.
Burnsmacdonald
- Vehicle Model: TJ
OK, thanks
