Any body else put in a mopar oil/ coolant heat exchanger?
mine failed.
http://www.ausjeepoffroad.com/forum/sho ... p?t=142232
going to go with a external oil/air heat exchanger on a thermostat.
aftermarket mopar oil/ coolant heat exchanger faild
rainman
- I think I'll order a "tab"
- Vehicle Year: 1995
- Vehicle Model: XJ
Obd1 scanner.
'95 sport,4.6 stroker, 4.5" lift, 32"s, 4:10's, 8.25&SYE, taurus fan
Sydney Australia
Sydney Australia
Re: aftermarket mopar oil/ coolant heat exchanger faild
I did. Its working fine.
rainman
- Vehicle Model: XJ
well yes, and like most things it will continue to, until it does not.
however if it should fail fixing it is a messy & time consuming process. I was very lucky it happened at the local shops 1 km away.
Not in 2 weeks time,on the camping trip towing my trailer 500km away from home.
At least a oil / air heat exchanger if it springs a leak it does not fvk up the cooling system, incapacitating the vehicle.
however my application was more for controlling excessive oil temp while towing in summer, not for quickly getting the engine oil up to operating temp during cold north american winters.
ie a oil air heat exchanger will cool oil just fine, but it can not warm it up.
Obd1 scanner.
Sydney Australia
Sydney Australia
