timing on comp 68-232-4
- Vehicle Year: 1981
- Vehicle Make: amc
- Vehicle Model: eaglesx4
Who is running the comp 68-232-4 ? Where is your timing at during idle ? Thanks
Re: timing on comp 68-232-4
Ignition timing is non-adjustable and set by the ECU.
You're probably referring to the injector firing synchronization with the spark and that's also fixed unless you cut one of the ears from the distributor hold down bolt tang and rotate the distributor.
Are you having any idling or drivability problems?
- Vehicle Make: amc
Running carb,old school lol . 1981 AMC eagle sx4
