Water Pump
bofish52
Water Pump
Post by bofish52 »
Does anyone know if a 258 Flowkool water pump will fit on a 4.0 block. Read somewhere about someone dirlling a extrs bolt hole.
Want to stay with all org. mounts and V belts.
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Re: Water Pump
Post by amcinstaller »
you said vbelt so im guessing youre on top of the fact that 4.2 water pumps go the other way from 4.0s. not sure about the mounting though
jonemere
Stroker Displacement: 3.9L
Vehicle Year: 1999
Vehicle Make: 1999
Vehicle Model: sx4
Water Pump
Post by jonemere »
In the tower is a adjustable pressure valva, just a little screw thing, turn it up and the pump works on a higher pressure, turn it up too much and the pump will cut in and out for no reason and burn out.
Users browsing this forum: stevusc and 1 guest
