I have a Newcomer Racing Stroker being built and want to see what fuel PSI I will need to make the Holley happy. I've read between 4-7 psi, but thought I'd ask before I start planning on what to do.
Thanks in advance
Carb'ed Stroker with 470 Truck Avenger what PSI for fuel
cuban11182
- Learning to use the board
- Stroker Displacement: 4.9
Re: Carb'ed Stroker with 470 Truck Avenger what PSI for fuel
Whatever pressure the carb manufacture recommends.
Ultimate fuel/air metering will be determined by the carb jets, springs and adjustments.
amceaglesx4
- Vehicle Year: 1981
- Vehicle Make: amc
- Vehicle Model: eaglesx4
Holleys prefer 7 psi. Carter and edelbrock about 5
amceaglesx4
- Vehicle Make: amc
Honestly you will probably have better throttle response with the 390
