probelm with supercharger
97XJM62
Post by 97XJM62 »
I installed a m62 supercharger kit on my 4.6 stroker a while back. It ran fine for about a month then but now it occasionally back fires under 1000 rpms. It also didn't seem to increase output much. I replaced the mpa sensor, tps, and cps and that didn't work. Any ideas? :cheers:
tia
tommy
jeepxj3
Vehicle Model: xj
Re: probelm with supercharger
Post by jeepxj3 »
IDK but maybe spark plugs or vacuum hose leak.
97XJM62
Post by 97XJM62 »
I was not able to find and vac leaks. I bought it used so maybe its missing something? It looks like its similar to this one http://www.cherokeeforum.com/attachment ... edium-.jpg
Reelm n Rubi
Learning to use the board
Post by Reelm n Rubi »
did you add electronics to add more fuel?
2003 Rubicon Automatic
4.7 Stroker with Hesco Aluminum head, .060 KB944 forged pistons, and Comp Cams grind.
Avenger supercharger w/ Split Second Fuel mngmt. system running 6.5 lbs of boost
Full Traction 4" LA , Moser Cro-mo axles with Super joints
vashxj
Vehicle Year: 1999
Post by vashxj »
is it building boost? how is it tuned?
97XJM62
Post by 97XJM62 »
Its building about 3 psi of boost.. it came with some sort of black box tuning module that I believes plugs into a injector or sensor on the manifold.
97XJM62
Post by 97XJM62 »
Anything I can try? Anyone recognize the manufacturer of this kit? Maybe get in touch with them and see what is missing.
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
any numbers on the box?
97XJM62
Post by 97XJM62 »
at first I didn't see anything bur with a closer look there was a cf decal on it. removed that and it says splits second ftc1. Also another number on end, but that came up with the cf decal I removed.
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
97XJM62 wrote: It also didn't seem to increase output much.
How was the output the first month? And now it backfires at 1000rpm and less output?
97XJM62
Post by 97XJM62 »
From what I remember the output at first was pretty good. its down a bit now. the backfiring usually happened below 1000.. sometimes it doesn't/
I'l call splits second tomorrow they might be the people familiar withthis supercharger.
