I've ready many different things about this.
Is it better to use a remix block or a HO block?
If HO block is recommended how can I be sure it's a HO block and not remix?
Im going to be using the clegg stroker kit
Thanks
Remix stroker
Coppertopneo
- Strong Poster
Re: Remix stroker
The early 87-90 Renix engine blocks will have a
53005535 casting number on the side of the block along with a provision for a knock sensor. Other than that I don't see any significance or reasons not to use it as the basis of a stroker.
If you call or email me i'd like the opportunity to point out some of the benefits of my stroker kits.
Thanks,
Bishop-Buehl Racing Engines
531 N. Lyall Avenue
West Covina, California 91790
Work (626) 967-1000
Fax (626) 967-7836
Cell (626) 673-2203
Thanks,
531 N. Lyall Avenue
Work (626) 967-1000
Fax (626) 967-7836
Cell (626) 673-2203
Re: Remix stroker
Either type of block would do fine. Just make sure that any block you find is serviceable.Coppertopneo wrote:Is it better to use a Renix block or a HO block?
If HO block is recommended how can I be sure it's a HO block and not Renix?
Keep in mind that the Renix block uses the same type of main bearings as the 4.2 block with the locating tangs offset to one side, whereas the HO block uses main bearings with locating tangs in the center so you need to be aware of the difference when ordering new main bearings.
Also be aware that some Jeep blocks have different bosses for the engine mount bolts so if you have a Cherokee or Wrangler, you'll need a block that came from a TJ, XJ, or YJ. If you have a Grand Cherokee, you'll need a block from a WJ or ZJ.
What make and model is your Jeep?
