Fuel Requirements?
nokool
- Vehicle Year: 1987
- Vehicle Make: AMC
- Vehicle Model: Comanche
Fuel Requirements?
Hey guys, this isnt a stroker related post, but it involves a 4.0 and a supercharger!!
so im sure most of you are familiar with the fact that the factory fuel pressure regulator is vacuum controlled and mounted to the fuel rail. well when i mount my Eaton M90 it will be useless. I already have a 45psi out tank fuel pump. my concern is regulating my fuel pressure and eliminating the old regulator and mounting a fuel line to it. i dont know if a aftermarket static fuel pressure regulator will be able to keep up with the range of fuel demand. any suggestions?
BADASYJ
Re: Fuel Requirements?
Search this forum, someone just posted a thread about a homemade flow through fuel rail with an adjustable regulator . Might be just what you need.
