ATK Baja stroker
Witha K
Vehicle Model: WJ
ATK Baja stroker
Post by Witha K »
So I'm in the process of purchasing all the supporting components for the motor and my questions are this:
ATK recommends a 62mm throttle body and 24lb injectors but I'm curious if using a 68mm throttle body and maybe 30lb Accel injectors would be advantageous....suggestions?
Re: ATK Baja stroker
Witha K wrote:I'm curious if using a 68mm throttle body and maybe 30lb Accel injectors would be advantageous
Simple answer: No
