Exhaust mount on crossmember 1998 xj
rammit11
Post by rammit11 »
HI, looking for some info about the exhaust pipe hanger that is on the transmount crossmember area. I am looking to replace that rubber isolator and I am having trouble finding info on the part number or parts to replace mine as the rod that is welded to the front pipe is resting on the bottom of the steel cover that surrounds the rubber piece. I would like to replace this as I am getting some nasty vibrations from the head pipe feeding thru the crossmember and then thru the body.
