The build sheet quoted me a crane 750501 although they built it with a delta 991L that is 188/193 390 lift that was close to stock. I have reset the PCM when installing the motor. They sent me the crane cam and new lifters but i havent had it installed yet. With stock injectors and TB it idled well but would not pull over 3800 rpm without seemingly going lean and cutting out.
I now have a bbk 62 mm TB and Bosch 280155923 injectors as well as a flow daddy header and full k&n FIPK on it now. I reset the PCM again. It runs well but occasionally has cold start high idle and surges while in Neutral . it pulls hard at WOT all the way to about 4800 rpm.
I feel like it needs a custom tune.
First for the idle issue, second I don't like that it doesn't pull that hard off the line. It really has power from 2200rpm to 4200rpm
I was hoping it would pull earlier. That is probably the cam.
I contacted flyinryan and he doesn't email tune anymore. Also waiting back for an answer from Cristune.
Will a piggyback jet stage 2 chip make any difference or just wait. I haven't got a wideband yet as I don't want to purchase the wrong kind.
I know most of you would have went with a different cam but I needed a milder build that was gonna have great longevity and cost benefit with a warranty. Wife wasn't gonna have it with no warranty. Is it even worth it to out in the crane or just go with a different one.
Sorry if this has already been covered
