hi
I Have Jeep Xj 2000 and I Rebuild My Engine With Some Performance Part
I Work With 0331 CYLINDER HEAD with Ls1 valve 2.0 int 1.60 Ex Also With Porting Head and Intake i add ls1 Throttle
For The ECU I Have haltech Elite 550 and work whell
My Question is for the valve spring because i have now lunati 268/276, Lift .527/.547 which valve spring i can install with my head because i try compcam need to cat
any spring can be work without catting
thank
performance Valve spring
azooz252
- Vehicle Model: xj
- Strong Poster
Re: performance Valve spring
The spring that I use for a cam profile similar to yours is a 26975 Comp spring. I'd recommend using it in conjunction with a 4677 ID Spring locator, 774 Retainer, and 623 locks.
If you decide to go this route feel free to shoot me an email or call. I have everything in stock.
Thanks,
Bishop-Buehl Racing Engines
531 N. Lyall Avenue
West Covina, California 91790
(626) 967-1000
Thanks,
531 N. Lyall Avenue
(626) 967-1000
gonridnu
- Vehicle Year: 1989
- Vehicle Model: XJ 2 door
The cam is really pretty big for a jeep and puts you in an unrealistic rpm range for both the vehicle and the engine design. I would toss the cam and use one that is better for the application, and one that lets you utilize a spring that does not require cutting the head.
Installing too big of cam is the number one rookie mistake in engine building/designing. 6200 RPM? There is nothing you are going to do at that rpm range in an L6 with that kind of head design in a Jeep, unless you are racing. You may need a converter as well.
Using an Ls-1 valve and retainer, some +.050 locks, and a spring shim (id spring locator) I was able to install a new stock spring on a .448 lift cam at like 120ish on the seat and 250ish open (I don't remember read my build thread). You need to consider what you are doing with the vehicle/engine and build accordingly.
