Using the form CR Calculator these are the numbers I came up with any thoughts?
Cubic In. 279.9
SCR 9.64 : 1
DCR 8.13 : 1
Quench 0.0725
I think Quench may be diff. because Calculator didn't take milled head into equation.
Thanks
Number for review
oletshot
Re: Number for review
Milling your head doesn't affect quench. Milling your block does, calculator accounts for that though.
'98 XJ 2-door, '94 YJ.
Mgardiner1
Thats a lot of quench for 8.13 DCR. I'd like to see a tighter quench then that
bratcop
- Stroker Displacement: 4.5L
I think you will want your quench much closer to .045 if you want a DCR of over 8.0:1. With the DCR that high, you are going to need the quench tighter because you will need the help it provides to avoid the pre-ignition ping. I am at 8.0:1 with a quench of about .045 and it runs at 500 above sea level on 87 octane. Good Luck!
Bratcop
Bratcop
2001 GC Laredo
4.5 Stroker, 9.6 SCR, 8.1 DCR
Stock Valvetrain
24# Cobra Injectors
Bored Throttle Body
CAI
Ported and Polished 0331 Head
Zeitroniz WideBand O2 logger
Stock Valvetrain
24# Cobra Injectors
Bored Throttle Body
CAI
