98 TJ block into a 99 XJ
HAMBURGLER7
Vehicle Year: 1999
Post by HAMBURGLER7 »
As the title indicates, I am going to get a motor from a 98 auto TJ and rebuild it as a stroker for my 99 XJ 5 spd. Will there be any issue with the swap? I've read differing things.
Re: 98 TJ block into a 99 XJ
You might have an issue with matching the XJ engine mounts with the bolt bosses on the TJ engine block, and the TJ water pump is different from the XJ's so remember that when you order a new unit.
HAMBURGLER7
Vehicle Year: 1999
Thanks, I'll continue hunting for a Cherokee block in that case.
HAMBURGLER7 wrote:Thanks, I'll continue hunting for a Cherokee block in that case.
Good eye deer. ;)
Any XJ block from '96-'99 will do ('00-'01 have crack-prone heads) so there are plenty to choose from.
HAMBURGLER7
Vehicle Year: 1999
Already found a 99 Cherokee engine at half the price :D
