Forget Lube Locker for trans pan
optmaxx
Post by optmaxx »
I have an A999 3 speed on my stroker, and I've had a transmission pan leaking problem way before I built my stroker. Nothing worked, and I tried rubber gaskets, Lube Locker and finally the grey RTV. The grey RTV seemed to work for a while but eventually it started to leak, but in the end they all failed. I found out that Mopar makes an updated steel core rubber gasket for these pans which is great cause I've had great success with them on other parts pf my Jeep, and it got even better when I found out that Crown makes the exact same gasket but much cheaper.
The part number is 4295875AC and it's the same part# for Mopar, but Crown is %50 or more cheaper depending where you buy it. I bought mine at 4Wheel parts for $10.99, and got free shipping by shipping it to a store near me. My only complaint is that the store manager didn't call me when my order got there, and I found out when I called costumer service, but it was only a few days later so no big deal; I didn't start working on it right away anyways.
The hardest part was cleaning off the RTV some wiener (me) put on the pan, but after that, it was easy. I took it for a drive, and there were not leaks anywhere on the pan or bolts after, which is good cause if there were, it would start seeping almost as soon as I start filling up the transmission. My pan is old too, so it's probably not the straightest, but this gasket sealed it up great.
https://www.4wheelparts.com/Drivetrain- ... _Container
optmaxx
Re: Forget Lube Locker for trans pan
Post by optmaxx »
The A999 is on a 1990 Yj Stroker btw. I'm pointing that out because most places weren't clear on whether that gasket would fit my year A999, but I found out that it does with more research.
jeepman
Vehicle Year: 1989
Vehicle Model: MJ
Post by jeepman »
That's the Stock gasket for the 32RH which is basically a 999 but for Fuel injected Engines...
optmaxx
Post by optmaxx »
Cool, most sites like ebay would say that this wouldn't fit my transmission, but it does which is great. All auto parts stores only had the regular rubber gasket which turned out to be useless for me unfortunately; they should just carry this gasket and it's reusable, best one so far. Here's a list of the transmissions it should fit for reference.
https://www.morris4x4center.com/transmi ... 875ac.html
Product Details
Fits:
*1997-2002 Jeep Wrangler TJ with 30RH, 32RH transmissions
*1987-1995 Jeep Wrangler YJ with A999, 32RH transmissions
*1980-1986 Jeep CJ5 with A904, A909, A999 transmissions
*1980-1986 Jeep CJ7 with A904, A909, A999 transmissions
*1981-1986 Jeep CJ8 Scrambler with A904, A909, A999 transmissions
*1999-2004 Jeep Grand Cherokee WJ with 42RE, 44RE transmissions
*2001-2004 Jeep Grand Cherokee WG (Europe) with 42RE, 44RE transmissions
*1993-1998 Jeep Grand Cherokee ZJ with 42RE, 44RE transmissions
*1997-1998 Jeep Grand Cherokee ZG (Europe) with 42RE, 44RE transmissions
*1994-2000 Jeep Cherokee XJ with A904, A909, 30RH transmissions
*1981-1992 Jeep Grand Wagoneer SJ, J-Series with A999 transmission
jeepman
Vehicle Year: 1989
Vehicle Model: MJ
Post by jeepman »
Yup I have been using this in my CJ with a 999 since 97 but I just bought the mopar one as its cheap from the dealer
optmaxx
Post by optmaxx »
Well looks like I spoke too soon cause it still leaks from the rear of the pan, it's not as bad, but it still leaks. Looks like I may need a new pan, so I've been looking into an aluminum pan cause I've read bad reviews on some steel pans that still leak after install. I found this one that says it's for a A904 that's decently priced compared to others, but I was wondering if I could put this on my A999? Looks like the same shape as my pan, and I found that both a904 and A999 share the same gasket.
http://www.ebay.com/itm/TCI-Aluminum-Tr ... hw&vxp=mtr
So is that pan a good option for my A999, or is there a better made steel pan that people had success with? I also use ATF+4, and I heard that it's supposed to be thinner.
