Thermostat Temp
jamesgrammer
Vehicle Year: 1989
Vehicle Model: YJ
Thermostat Temp
Post by jamesgrammer »
Why would you want a 180 or 190 thermostat vs. a 160, wouldn't lower be better, why and or why not?
SkylinesSuck
Re: Thermostat Temp
Post by SkylinesSuck »
On a fuel injected motor the ECU will see the low temp and set air/fuel ratios and timing accordingly which probably wouldn't be ideal for fuel consumption or power. If you could tune for it though, it could help a bit. I run 180* stat with no noticeable effect.
