Broke my 4.7 in about two weeks ago using the break in procedure comp suggested used their oil new parts in the whole engine, checked clearances balanced rotating assembly... thought I did everything right but as my luck would have it after the break in process I found metal in the oil. Am I overthinking the metal thing or should I be worried? The oil looks like metallic paint, and has small scraps of brass colored material. Is this just normal new parts meeting eatchother and breaking in? Or is it worse?
It seems to run fine but I cant get over this metal thing, I changed the oil after initial breakin and used another batch of comp break in oil drove on that for 20 miles and seemed the same when drained as the first run of oil. I now have regular oil in it but am to worried to drive it to see if the metal keeps up. I don’t want to damage any parts that might be worth money if I have to get out of this thing. So comes the question is the metal normal and a brand new engine or should I be worried?
What went wrong
Jarrods2000tj
- SkylinesSuck
Re: What went wrong
When I did my cam swap (after eating a lobe/lifter on the previous cam) I had a substantial amount of metallic stuff in the oil for the initial break in oil and two oil changes after that. The third one looked okay, but I'm a still watching closely and don't really consider myself out of the woods until the next oil change comes up clean. Time will tell.
I would say change your oil again and see what it looks like. I also run a magnetic drain plug and watch it closely whenever I change the oil.
Re: What went wrong
It might take 100 miles or more to see any reduction in the amount of metal particles in the oil so as long as the engine sounds normal, I wouldn't panic. I'd continue using break in oil for the next 600 miles (1000km) and add a magnetic drain plug to the oil pan to catch ferrous particles.
- Stroker Displacement: 4.9
Re: What went wrong
No amount of visible metallics is acceptable.
if the block and internals were cleaned properly there should not be any particles to the naked eye.
Something is very wrong and its not going to get better by itself.
- Strong Poster
Re: What went wrong
X2,jsawduste wrote:No amount of visible metallics is acceptable.
The oil might have a slight gray color because of the Molly on the cam, and a combination of honing oil impregnation, rings and such during breaking in.
If it's anything more than that you have some problems.
In Chris's case it was debris from the previous cam failure.
If there's ever a concern I recommend cutting the oil filter open and looking at the pleets in the filter.
If anything is bad happening in the engine the oil filter will show signs immediately.
Wish you luck
Jarrods2000tj
Re: What went wrong
When I cut the filter open there wasn’t metal debris stuck to the pleats of the filter but has metal dust/small chunks where I had the magnet on the filter, also metal dust on the magnetic drain plug, also the small chunks of brass colored material in the bottom of the drain pan are odd.
Re: What went wrong
A light trace of fine metal dust is normal but chunks of metal definitely aren't, and what you're describing sounds like bearing material. This is more worrying. How's the oil pressure?Jarrods2000tj wrote:When I cut the filter open there wasn’t metal debris stuck to the pleats of the filter but has metal dust/small chunks where I had the magnet on the filter, also metal dust on the magnetic drain plug, also the small chunks of brass colored material in the bottom of the drain pan are odd.
Two potential scenarios are either cam walk causing accelerated cam bearing wear, or an improperly seated torque converter (if automatic) causing accelerated thrust bearing wear. In both cases the oil pressure could remain normal, and you may not hear any unusual noises, until the degree of wear is well advanced.
Jarrods2000tj
Re: What went wrong
It is an automatic, but when I tightened the torque converter bolts they had to pull the torque converter up to the flex plate. The cam has a spring loaded pin in the bolt to keep it from walking up against the timing cover
Users browsing this forum: Amazon [Bot], Google [Bot] and 3 guests
