Fender Compadibility
Does anyone know if fenders from a MJ (Commanche) will fit on a 4 door XJ (Cherokee).
Thanks!
Shark
Re: Fender Compadibility
Post by Shark »
i would assume so. never tried it.
'95 XJ 4door 4.0 aw4 2" 31's
I would like to know for sure... Someone finally found some fenders that were the same color as my Jeep, and i definetly need a new drivers side one, possibly a passengers side. The donor vehicle however is a MJ. Last time i was at the junk yard they looked awefully similar.. but i never actually knew if they would work.
Shark
Post by Shark »
tkgibbs27
Post by tkgibbs27 »
everything on the xjs front end is interchangeable with the mjs.
Jeep designers based its body, styling, and suspension on the Cherokee. - wiki
-Ty
5-90 posted this on NAXJA:
5-90 wrote:1984-1986XJ and 1986MJ are identical
1987-1996XJ and 1987-1992MJ are identical.
You can also do the 1997-upXJ swap onto an MJ, if you're so inclined.
The reason for the 1986/1987 break is that the front clip was lengthened slightly to accommodate the inline six.
So it appears that the MJ fenders from a 86 WILL NOT fit my 90 because of length issues.
Shark
Post by Shark »
news to me. how much length we talking here?
tigerShark wrote:news to me. how much length we talking here?
Dont know ... im having the guy that found the fenders get back to me with some measurements so i can make a comparison.
Shark
Post by Shark »
how long have you been looking for matching fenders for your XJ?
tigerShark wrote:how long have you been looking for matching fenders for your XJ?
Since December 2006, i hit the deer in November!
http://s109.photobucket.com/albums/n57/ ... nd%20Deer/
Im still using the blue fenders from factory, but my passenger size is bent outwards a bit (might be able to fix) the drivers side however will have to be replaced (is bent in pretty good at the end where it meets the corner lamp). I had to smack the hell out if it with a hammer so i could get the damn replacement gray header panel on.
I took these right after i got it running again:
http://s109.photobucket.com/albums/n57/ ... t%20Fixed/
Needed new header panel, condensor, radiator, electric fan, power steering pump pulley (it exploded :boom: ended up just replacing the pump with one from the junkyard .. a replacement pulley wouldnt go on very well), and a belt. Only a few of the fins for the mechanical fan clutch were broken from grinding into the radiator. I have since removed it and installed a taurus fan. I also now have a nice straight chrome bumper. The two nutsert/pinned tab thingy that extends off of the frame to hold the factory bumper on was bent sideways 90 degrees to the left. Fortunately it bent back just fine and allowed me to install the replacement bumper at a later time. I cant wait till i have enought to get a JCR bumper with the frame tie ins .. ill feel better about that area!
I guess im just anal .. and i wish it still looked like this:
http://i109.photobucket.com/albums/n57/ ... CF1788.jpg
At least the color matched even though the clearcoat was a failure!!! Its all going to get painted in the future no matter what... just time and $$$.
Shark
Post by Shark »
if your going to repaint it anyway maybe just find any ol replacement fender from the JY and primer it for now.
tigerShark wrote:if your going to repaint it anyway maybe just find any ol replacement fender from the JY and primer it for now.
All of them here in my area are dented/ruined.
Plus, as i said im anal... i wouldnt drive around for more then a month with a huge peice of different colored fender on my heep. It would drive me nuts. Fortunately the header panel only has a small strip that has visable paint. It still drives me nuts!
I think its mainly because its my only vehicle / daily driver at the moment.
Shark
Post by Shark »
its a shame most of the fenders out there in your part of oregon are dented. there must be 15 XJs and a few MJs at my local yard. fenders are $29.99. all of them seem to be in good shape. no wrecks. i wonder what shipping from florida to oregon on a fender goes for...
tigerShark wrote:its a shame most of the fenders out there in your part of oregon are dented. there must be 15 XJs and a few MJs at my local yard. fenders are $29.99. all of them seem to be in good shape. no wrecks. i wonder what shipping from florida to oregon on a fender goes for...
Im gonna say 30-40 bucks.. Do you have some blue ones?
Shark
Post by Shark »
ill check it out next time i go and take a pic with my phone. it looks like a light blue form the pics.
