I have a 1990 YJ with a 4.2L running a MC2150 and MSD 6AL ignition. That will be replaced with a 4.7L built from a 2003 TJ motor using a Holley ECU with the factory coil rail.
This motor started life as another gentleman's 2005 TJ project. He had problems, gave up, and then sold the jeep in frustration. The next owner of the TJ with stroker was also not happy with its performance. That gentleman took the jeep, with a stock 4.0, to an off road shop and had them put the boring motor in it. After multiple conversations with the first gentleman and his machinist, I bought the 4.7 stroker from the shop owner.
Here are the details as I know them for my new 4.7L stroker project.
- 2003 4.0 block
- 1982 4.2 crank
- 4.0 rods
- KB944-060 pistons
- Tuppy cylinder head with larger valves, beehive springs, bronze guides, a 3 angle valve job, roller rockers, and some port work
- The block (0.027) and cylinder heads (0.10) were milled to raise the compression ratio. Numbers were best memory from the machinist.
- 10:1 compression ratio
- ARP bolts or studs for everything
- All new bearings for everything
- Custom mains girdle.
- Custom solid lifter bullet cam. <- I will add the details when I find the picture of the cam card.
- 70mm throttle body
- 27 lb/hr injectors
- Banks header
- 93 octane
The huge throttle body & bigger injectors stayed in the TJ. I banks header stayed as well, but I had one of those already.
Why did the original gentleman give up on it?
- Error codes all the time. He PCM was never touched by Ryan, so I am gambling that the error codes was caused by the engine being too modified for a stock tune.
- A ticking noise. Both the machinist and original gentleman believe this is coming from the lack of correctly setting valve lash with a solid lifter.
