Question
Lowerthnu
- Vehicle Model: Grand
Question
98 jeep grand cherokee pulled out the 4.0 and dropped a 4.6 stroker in used all 4.0 parts now having cps code put new cps in and still have codes my question is... Is there a difference between a 4.0 flywheel and the 4.2 flywheel automatic?
Re: Question
Absolutely, the 4.0 flywheel/flexplates have the "tone ring" for the CPS to see, none of the 258/4.2's were injected so they don't have tone rings.
You should have reinstalled the flex plate that was originally in the Jeep.
Re: Question
x2.
Reinstall the flexplate that was originally bolted onto the back of your 4.0 and that'll solve your problem.
Lowerthnu
Re: Question
I put the 4.0 flywheel back on I put a new cps and still getting loss of cps signal checked wires all look good new distributor can't figure it out
DaemonForce
- Vehicle Year: 1983
- Vehicle Make: American
- Vehicle Model: Eagle
Re: Question
The tone ring on a flexplate is smaller circumference than the tone ring on a flywheel. Your crank sensor most likely isn't engaging at all. Don't ask how I know this.
,__,_____,__, ~A-M-C YA!
//___}/,_ll,_\__\,_____
,l_/¯\_l__ll__l__/¯\(¤≡¤)
(o))o)) (o))o))
(o))o)) (o))o))
Lowerthnu
Re: Question
When I pulled the old one out the end was eat up like it had hit the flywheel
