4.0 Block question
Sharnick
4.0 Block question
My current Jeep is a 1998 TJ, but the motor i picked up to do the stroker build was from a 97 Cherokee. I had done the research and saw that this should swap in no problem, but I just wanted to make sure. Thanks!
Re: 4.0 Block question
You might wanna check that the engine mount bolt bosses on the block match up.
There may also be a difference in the bolt bosses for the AC compressor/alternator mounting bracket.
