Map Sensor 101
Map Sensor 101
Did a [size=50]little[/size] searching on adjusting a MAP sensor via voltage.
What I found calls for MP sensor voltage change in 3/4 and WOT throttle.
From a couple posts on this forum. Seems (suggests) that you folks have expanded things a bit and are able to change MP influence on smaller throttle positions.
OBD 1 or OBD 11 only ?
I`d like to play around with low and mid range tuning a bit. Being limited to fuel pressure alone is not the best way to go.
Hopefully a Mega Squirt is in my future but it may be a bit before that happens.
Re: Map Sensor 101
Changing the MP voltages at lower RPMs and not WOT (closed loop) just changes the fuel trims.
