Intake manifold and header project
BcurpKodiak
Post by BcurpKodiak »
My stroker is going in soon. It's hanging from the hoist, just finishing a few last things.
Once the summer is over and I'm done fishing I plan to start a custom intake manifold and header to pick up a little more power. The cylinder head I'm running is the eddy head ported by Russ showcased in these 2 threads https://www.naxja.org/forum/showthread.php?t=1120948
viewtopic.php?t=4899
That thing flows better than some aftermarket SBC heads. Here's the solid cam I'm running from Lunati (they made it just for little ol' me)
We're all very familiar with the older "log style" intake. I want to cut off the "plenum" about where the red line is. It should to me, run a lot like a single plane intake and that's what I'm shooting for
I've done a lot of reading about custom sheet metal intakes. It seems that you want a plenum with the same volume as your engine's displacement. Mine is about 284 CI. It would be fairly easy for me to cut this intake apart, build a square/rectangular plenum that is 284 ish CI and weld it to it. I would cut the TB mount from the old intake and weld it to the new manifold plenum (and port it out to 70mm). Plan is to port the crap out of the runners where they meet the plenum and attempt to make them like velocity stacks. The cylinder head side of the runners/ports would be ported in the same way Russ port matches them.
I would then like to build or have built a custom header with 1.75" primaries based off data from this article http://www.superchevy.com/how-to/148-04 ... -shootout/
I compare my stroker to a SBC 383 a lot. Each engine has a displacement of about 47 CI. The 383 in that article has 440 hp, which if broken down per cyl is 55 hp per cylinder X 6 = 330 hp (to compare to a Jeep I6 stroker). This is why I believe 1.75" primaries will work well for me. I hope to possibly make 380 HP at least with a custom intake and header.
The high flowing head, big cam, big intake and header should work well together and work in about the same RPM range hopefully. I'm running 33's and 5.13's. At the same time I do this I might change to 5.38's as well. I have a 2800 stall converter
So, what do you guys think??
SkylinesSuck
Re: Intake manifold and header project
Post by SkylinesSuck »
Very interested to see how it turns out!
McSyd
Vehicle Year: 1985
Vehicle Model: Cj7
Post by McSyd »
Any updates on this?
Cummins90
Post by Cummins90 »
McSyd wrote: February 18th, 2019, 6:02 am Any updates on this?
I wouldn't invest that much time in something that would produce so little, if any, gains. If you want a bigger plenum go with the late model intake. If you are doing it to mount a supercharger I would still discourage it because of the moderate power gains per dollar invested. A turbocharger is easier to fabricate a mount for and will provide gains up to and beyond what a stoker can achieve.
The Beast
Post by The Beast »
I actually did this and the gains are extremely noticeable especially the top end. Data logs show that you can actually run out of injector
and find that you'll start seeing a limit to a 70mm TB. I got a twin 58mm and I'm starting to max it. My 24lbs injectors go 100%duty at 90%
throttle. That shouldn't happen on a NA stroker but that's because the stock Int/Ex. manifolds are so F'ing pinched off it laughable.
That's why I didn't waste time with that stupid horseshoe intake and crap aftermarket headers and fabbed my own.
My Jeep is like having a conversation with two lions, in both my ears, inside my head, from the outside.... I hear good things from them!
BcurpKodiak wrote: May 17th, 2018, 4:46 pm My stroker is going in soon. It's hanging from the hoist, just finishing a few last things.
I'm also interested to see how this project turns out. I like the ideas going into it.
When building a larger plenum for the intake manifold, keep in mind that you'll need to clear the brake booster and leave enough clearance for the hood with the throttle body mounted and the airpipe attached (unless you mount the TB sideways on the driver's side and modify the linkage).
