Too much power for stock transmission?
bmax998
Vehicle Model: G.Cherokee
Post by bmax998 »
Alright, newbie here, just starting out my build. I’ve looked all around this forum for answers and still have yet to find a real definitive answer.
So I’m lookng to build the 4.6L Low-Buck Stroker, heres the recipe:
4.6L low-buck stroker
Jeep 4.2L 3.895" stroke crank
Jeep 4.0L 6.125" rods
Custom forged +0.030" bore pistons, compression height 1.380", dish volume 18cc
9.6:1 CR
Russ Pottenger ported HO 2.00"/1.55" 62cc cylinder head
0.043" quench height
Ford 24lb/hr injectors with adjustable FPR or MAP adjuster for '87-'95 engines, Ford 24lb/hr injectors for '96-'04 engines, '99-'00 Chevy LS1 26.2lb/hr injectors for '05-'06 engines
268hp @ 4900rpm, 326lbft @ 3500rpm
And i have the 42re auto trans in my 96 ZJ. Now with that much hp and torque, will be fine keeping my stock transmission? I’m just worried here that i’ll be driving and i’ll go to lay on it to get up to speed or i’ll be rippin on a trail and my trans will go. I don’t want to pull it to rebuild and if all possible I do not want to swap it out for a different trans. So will I be alright? If not, are there other drivetrain mods I can do so that there isnt so much stress on the trans? Thanks in advance for the help, it’s MUCH appreciated.
Vehicle Make: Jeep XJ
Re: Too much power for stock transmission?
Keep the stock tranny and just install an auxiliary tranny fluid cooler on the return side from the stock unit. Heat is the enemy of an auto tranny so keeping the fluid cooler will prolong its life. You can also install a trans. temp. gauge to monitor things.
Here's another tip. When stopped at traffic lights or in non-moving traffic, keep the tranny selector in P or N rather than D so that you don't have the torque converter spinning and generating heat at a time when there's no cooling airflow under the tranny.
bmax998
Post by bmax998 »
Cheromaniac wrote: ↑June 3rd, 2018, 3:50 am Keep the stock tranny and just install an auxiliary tranny fluid cooler on the return side from the stock unit. Heat is the enemy of an auto tranny so keeping the fluid cooler will prolong its life. You can also install a trans. temp. gauge to monitor things.
Thank you for the advice! That was just what needed for some peace of mind about the transmission.
