Has anyone tried the injectors from a '95 5.2L in their build rather than the Mustang 5.0 injectors? I know the Mustang injectors are 24# and the 5.2L injectors are 24.3#, very close at a similar pressure (not exactly though). Just wondering if there was a reason they aren't mentioned or used as much.
I have a set of the Mustang injectors and keep getting the dreaded OBDI code 27. I have replaced and checked everything but the injectors themselves and since I bought them used I don't have the highest confidence in them.
'94 Wrangler with a '93 4.0 bored +0.030, SCAT 4.2 crank, decked block, stock cam, stock head, stock TB, new MAP sensor, new(ish) O2.
'95 Grand Cherokee 5.2L Injectors
Shade_Tree
- Vehicle Year: 1994
Re: '95 Grand Cherokee 5.2L Injectors
The '95 ZJ injectors (53030262 rated to flow 24.6lb/hr can @ 39psi) are indeed suitable for a stroker application in an OBD 1 Jeep with a 39psi fuel system.
Shade_Tree
Thank you for the reply, I appreciate it.
They seem a little cheaper, any reason why you don't hear about them as much?
Maybe it's because some of the newer injectors are more popular and these have merely been forgotten.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 1 guest
