Anyone ever use dome pistons on strokers
Mines at 4.000” bore trying to find some ford or chevy domes pistons tbat would work zero deck on block & cyl head
Dome pistons
aguiar_racer
- Vehicle Model: comanche
- Strong Poster
Re: Dome pistons
Why would you want to run a dome piston?
You'll be at 14.0:1 with a flat top piston.
Way more desirable to run a flat top over any dome piston.
My advice would to run a 3.970 bore piston allowing you to run a commonly available off-the-shelf head gasket.
This is a common flat top piston that I keep in stock.
That said, i'll build you anything you want : )
Shoot me a call or email if you'd like more information on my Pistons.
Russ
Russ
gsune
- Stroker Displacement: 4.5
- Vehicle Model: cherokee x
Re: Dome pistons
Hi, what do you think about using a ford explorer 4.0 pistons? 6.125" rods they are lighters 100 grams. must work the rod pin diameter
- Strong Poster
Re: Dome pistons
Why not run a piston for a Jeep?
Just about any specification you choose.
$515.00
Bishop-Buehl Racing Engines
Work (626) 967-1000
Cell (626) 673-2203
[email protected]
gsune
Re: Dome pistons
In my country (venezuela) i can buy a set of 6 new pistons for 100 us$
