Hi all, Happy to find this forum.
I am making the leap and getting the parts needed to swap my 89 YJ's 4.2 head for a 4.0.
Reading through this forum, I have found much of the information and it is greatly appreciated.
Two questions I have which I have not been able to locate:
I modified my AX15 bellhousing to accommodate an external slave cylinder. It had a spot for a crank sensor. Would I be able to purchase and use a stock Crank Sensor instead of purchasing the kit from Hesco or similar?
The next question; is there a document which shows the wires to keep and the ones to remove from the engine wiring harness of the donor vehicle. What about the fuse panel from donor vehicle?
Thanks
Making the leap
Shrek
- Vehicle Year: 1989
