I'd like to get an idea on what some of these engines we've built make for cranking pressure , measured with a compression guage.
Mines a short rod , twelve counterweight 4.7 with + .060" unmolested Sealed Power #677CP pistons. Piston dish volume on these is 15.1 cc
Cranking pressure is 185 psi
What's yours ?
Cranking pressure ?
Gearhead88
gremlinsteve
Re: Cranking pressure ?
sounds good to me. whats the quench? which cam is this?
steve
steve
185 cranking pressure? what gas do you run?
gremlinsteve
true but what can and at what quench. ive run stuff over 250 cranking on 93 pump with no issues.
a/f and a good tuner would help also.
steve
steve
Gearhead88
I only run premium , there's no way I'll run with mid or reg.
Cam is Comp # 68-232-4 , installed straight up.
Quench is not where I could / should have set it , I'll have to look at my build notes to get a number , I remember not being happy with it and went ahead any way due to a very long backlog of work at the machine shop I used and could not stomache yet a further delay to the completion of the engine. I was thinking about freshening the engine in the future and dealing with it then . I am building a second engine that will not be under such tight time constaints so I could take care of the quench on that one . The next one will probably be a long rod / four counterweight version , I'm still gathering parts and have a nice cylinder head prepared to use on it.
No tuner used on this one either , , I did use Accel 24 lb/hr injectors , Rubicon express 62mm throttle body , ported head w/ stock sized valves , Bank's full exhaust system.
I'm planning on adding an air /fuel ratio guage in the near future.
Other than busting a few rocker arms , it's been a great engine.
