Stroked 1992 XJ Questions
rcmf5525
Post by rcmf5525 »
I have a '92 XJ that I will be stroking soon and was wondering what computer/sensor modifications I need to do. Unichip does not produce a piggyback for pre-93 and I have not found any good information here or on Pirate. Thanks for your help...
Robert
Mgardiner1
Stroker Displacement: 284 CI
Re: Stroked 1992 XJ Questions
Post by Mgardiner1 »
24# ford injectors is all you will NEED. Chances are the stock ECU will do a good job handling the AFR, i know mine does.
Boilermaker
Post by Boilermaker »
Apparently they do, i have no experience with it tho. More info here:
viewtopic.php?f=5&t=387
1992 MJ Eliminator
Stroker in progress: Lunati Cam, Diamond Pistons, 4.0L Rods, 4wt Crankshaft 3727 Casting, Clifford Ceramic Coated Header,
99+ Intake, 62mm Throttle Body, 24# Ford Injectors
Comanche91
Vehicle Year: 1991
Vehicle Make: JeeP
Post by Comanche91 »
I have one on my 91. It's not exactly PNP; has to be hardwired into the ECU harness and will work on all OBD1s. Easy to do.
Mgardiner1 wrote:24# ford injectors is all you will NEED. Chances are the stock ECU will do a good job handling the AFR, i know mine does.
Same here. Ford Racing 24lb injectors, stock computer, stock MAP voltage, and stock fuel pressure regulator. Goes like a raped ape. :mrgreen:
Mgardiner1
I think it depends more on how nuts you wanna get on tuning.... mine could run a scosh richer and WOT (and i plan to use my PSC to impliment this when the weather warms) There also seems to be a real HP wall around 4500 RPM, my friend felt it too, he asked if i let off the throttle cause thats how much it dips in power. I have yet to make a recording with my AFR setup to see what happens to the exhaust gas when that condition occurs
