A 3” throttle body..... kinda
- Biggrnjeep97
Hello all. 10 years ago i started on a 3” throttle body for a super charger project i had built. Things change and i lost track of time and money so the project sat stagnant. Recently, I was reinvigorated to work on my jeep. I think ive all but scrapped the idea of finishing the super charger(its forsale btw), but i still wanted a 3” TB for the head i had ported. This shut down has had me working(im a machinist by trade) really long hours so ive been using my down time to machine a new prototype, as the first one failed. I have no idea if ill have these produced en mass yet but i would like to chronicle the evolution as i go so you guys can motivate me and make suggestions. As you see it, it is 2.95” ID and needs a final boring on a lathe. I will make a new throttle plate and modify the stock shaft. This will use all of the stock parts in the stock locations with the exception of the MAP.
- Biggrnjeep97
Re: A 3” throttle body..... kinda
Here are some pics of the first one i made. I completely glossed over that the stock shaft couldnt be used with this design. I got really tired of trying to adapt throttle cables and TV cables in its new location on the supercharger. Also I miscalculated some distances and left almost no room for a bearing. In all this one didnt work. Back to the drawing board.
Tolemar
Nice work! keep us posted.
- Biggrnjeep97
Small update. Got the TB functional. I made a fixture for the stock throttle shaft and machined it to 3" width. Also made a new butterfly out of .06" 2024 alum. Needs some final fitting and some shorter screws but its ready to go. I still need to machine the intake to match. As a note, im unhappy with a few parts of my design. One of those is the width of the gasket flange. It gets very thin so i only bored this one to 2.950" to maximize the gasket surface. I have altered it in my CAD drawing so if i make more, it will be thicker all the way around at the flange.
- SkylinesSuck
- Strong Poster
Nice work.
I’ll be curious to see what your throttlebody base on your intake manifold looks like.
- Strong Poster
Answered my own questions by looking at all the pictures.Russ Pottenger wrote: ↑June 10th, 2020, 10:44 am Nice work.
:Note to self:
Don’t post on threads until after the 1st cup of coffee.
- Biggrnjeep97
Havent gotten there yet. The TB adapter on my supercharger is 1/2” plate bored to 3”. I will probably wind up welding, facing and drilling the manifold. I did make an adapter at one point for a durango TB but dropped that because the juice wasnt worth the squeeze IMO.
