Economical stroker questions
KarmaKannon1
Post by KarmaKannon1 »
Hi there. Noob beating a dead horse here. I picked up a Cherokee with a bad cylinder due to what I think is someone telling their machinist one thing and ordering pistons for something smaller. Anyway, I'm taking the block in next week to see if it can be bored enough to clean up the cylinder. If that doesn't work I'm trying to get another block.
Background aside... I'm looking at getting more power for a little extra cash. Don't want to go crazy with it, but if it's open and I'm already paying $5 I might as well pay $7 for some power. I'm looking at the clegg stroker kit that will set me at about $1000 in parts. I also have an option of doing a basic rebuild with a 232 crank. Does anybody have any other ideas to get some good returns with room for more later for less than that $1000 mark?
I'm already porting the head while I'm waiting for machinist and the rods and crank look to be in great shape along with the head. I was hoping to reuse my can for now if it looks good and upgrade later along with injectors, and so on.
https://www.cleggengine.com/jeep-4-0-st ... -1c-r.html
Also, should I have my block decked to help with quench on this kit? :deadhorse:
Thanks
Re: Economical stroker questions
Clegg's looks like a decent kit for a reasonable price. Unfortunately the IC944 pistons only have a 1.353" compression height which typically leaves a deck clearance of ~0.027". This requires you to mill the block deck to reduce the quench height.
Russ can supply you with a set of custom pistons that are the correct height and won't require block milling, saving you the cost.
KarmaKannon1
Thanks that's exactly what I wanted to know. I contacted Russ and I'm awaiting a reply. I understand it's a holiday weekend so it might be next week. I'm wondering if custom pistons and the scat crank can be had for less than the clegg setup and a deck milling. I guess we'll see.
How would I go about calculating deck height?
Talked to Russ today. He is currently slammed but is going to take a couple days off to catch his breath.
I`m sure he will be in touch next week.
KarmaKannon1
Cheromaniac wrote: May 22nd, 2020, 12:58 am Clegg's looks like a decent kit for a reasonable price. Unfortunately the IC944 pistons only have a 1.353" compression height which typically leaves a deck clearance of ~0.027". This requires you to mill the block deck to reduce the quench height.
I talked with Russ today. He was super helpful. I ended up scoring a 4.2 engine locally for a price I couldn't resist. The crank looks pretty good, but needs a grind. I think it's already 10 under so I'm hoping another 10 gets it it smooth, but it might take 15-20. Russ good me about his pistons that don't require me decking the block like you said. That along with the connecting rod upgrade sounds like a good way to go. I'll probably order the pistons this week and get the rods after next paycheck.
Long story short... Russ was very helpful and seems to offer some great products for these engines at, what I would call, a reasonable price. Yeah my budget is getting stretched a bit, but getting a solid rotating assembly seems like a good idea and I can get into cams and other fun stuff later. Build thread will probably follow.
Horse beaten thoroughly :deadhorse:
