New Comp 99+ Cams
TR1Hemi
New Comp 99+ Cams
Post by TR1Hemi »
Anyone seen the 99 up cams from comp, they look a little larger in diameter, the entire cam looks like it is the size of the base circle. Looks like it would solve a lot of issues, I know my 98 block has the tabs to drill the retention plate holes.
TR1Hemi
Re: New Comp 99+ Cams
Post by TR1Hemi »
205/213, .488/.507, 113
Tolemar
Post by Tolemar »
I have one and its basically ground on a factory wide lobe core blank. Uses the factory retaining plate and timing chain.I highly suggest you nitride it if your getting one.Contact Russell Potterfield as he might have what you want in stock.
Tolemar
Post by Tolemar »
Mine isn't the same grind as the above cam.
Vehicle Make: Jeep XJ
Tolemar wrote: ↑May 28th, 2020, 6:07 am I have one and its basically ground on a factory wide lobe core blank. Uses the factory retaining plate and timing chain.I highly suggest you nitride it if your getting one.Contact Russell Potterfield as he might have what you want in stock.
Er, I think you mean Russ Pottenger. ;)
Tolemar
Post by Tolemar »
Cheromaniac wrote: ↑May 28th, 2020, 10:14 pm
My bad lol, I have another buddy named Russel im always sending him text messages meant for Russ. Fricken sucks getting old lol.
