Flywheel Flange Height, Help!
Glacko
Vehicle Year: 1989
Post by Glacko »
What was supposed to be a painless swap has given me realization that the flywheel flange appears to be closer than I thought upon lining the transmission up. I have a 1989 Laredo and the shop was explicit in that this was only for an 87-90 L or M vin code Cherokee and had a new SCAT 3.895 stroke crankshaft. I had heard something about the harmonic balancer snout issue with some of these cranks but I haven't been able to find anything like this. I'm at a loss and I'm not sure if changing the flywheel will fix my dilemma or I'll need to find some sort of spacer solution, my way of measuring isn't exact but i think it gets the point across
Glacko
Vehicle Year: 1989
Re: Flywheel Flange Height, Help!
Post by Glacko »
From what I can tell the old block was 4.8mms from the block to the flanges inner face, and 9mms thick, while the new one is about 1.75mms and has a flange thickness of 9.75mms.
https://www.ebay.com/itm/164079516682
The old listing
