More Gauges/Sensors
Sailboy42
Vehicle Model: YJ
More Gauges/Sensors
Post by Sailboy42 »
Are there any gauges or sensors that can be added to the engine that would be worthwhile to monitor the motor?
Re: More Gauges/Sensors
I'd added an engine oil temperature gauge plus an air/fuel ratio gauge that ran off an O2 sensor that I had placed in the header collector.
http://www.angelfire.com/my/fan/oiltemp.html
Oil temp and Air fuel ratio would be the first 2. After that I would do a redundant oil pressure gauge and a transmission temp if you have an auto.
Sailboy42
Vehicle Model: YJ
Post by Sailboy42 »
Okay, that goes along with my research.
Sailboy42
Vehicle Model: YJ
Post by Sailboy42 »
Any suggested brands or placements?
Sailboy42
Vehicle Model: YJ
Post by Sailboy42 »
These are what I'm thinking:
Oil Temp- AutoMeter 9240
https://www.summitracing.com/parts/atm-9240
Wideband- AEM Electronics 30-0334 - AEM Electronics X-Series Wideband UEGO Air/Fuel Sensor Controller Gauges
https://www.summitracing.com/parts/avm-30-0334
Aeromotive Fuel Pressure Gauges 15633
https://www.summitracing.com/parts/aei-15633
-this I will connect to a gauge port on my regulator
Does anyone have experience with these?
Andre_ITALY
Learning to use the board
Vehicle Model: TJ 4.0
Post by Andre_ITALY »
I am also looking for an a / f meter for my 97 TJ! :banana:
https://www.aemelectronics.com/products ... uego-OBDII
or
https://www.aemelectronics.com/products ... ller-gauge :huh: :huh: :huh: :huh:
What advantages do I have with 30-0334 (obd2) ?
An EGT gauge is a waste of money on n/a application?
THANKS!
