Help crank wont turn when i tighten cap 3
Mattwv
- Vehicle Year: 1991
I bought a crate stroker kit and am assembling the block. When i tighten cap 3 which has the thrust bearing it locks the crank up. Any ideas?
- lamart72
- Vehicle Model: Comanche
Re: Help crank wont turn when i tighten cap 3
Start by looking at the bearing shells. Are they the correct size? Is the crankshaft standard sized or are the mains ground undersized? Did you measure the crank mains with a micrometer? At that point, did you have all the other caps and bearings on? Were they torqued down? Give us a rundown on the specs and what you did to the crank right before you had this problem so we can get a better idea of what might have happened.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 2 guests
