GM ECM Or Stock for 4.7 Stroker....
vernors
Post by vernors »
Hi,
Just completed 4.7 stroker with following parts:
HESCO MPFI, 1994 ECU
7120 Head, port matched to exhaust and intake
2000+ Intake
Roll Master Timing Chain
4.2 Crank
4.0 connecting rods
4.0 Renix Block
Keith Black KB424 +0.060" bore pistons
Bishop Buehl Racing/ CompCams 68-235-4
Bishop Buehl Racing valve springs
Victor Reins.043" head gasket
0 deck quench
Meling High Flow Oil Pump
Ford Cobra 24 lb injectors
Holley Adjustable Pressure Fuel Regulator
62 mm Throttle body
jCC'd the head and it's 57.6 cc's.
Static Compression: 9.26/1
Dynamic Compression: 7.8/1
Intake valve closing angle: 58
Considering going with GM ECM (#1227727) and using TunerPro to make adjustments.....although, I don't know if its worth it vs staying with stock ECM and adding adjustable MAP.
The engine runs pretty smooth and starts well, but I wonder if I'm leaving power on the table without specific tuning. I'm not going to add supercharger or turbo.
Thoughts?
Cummins90
Re: GM ECM Or Stock for 4.7 Stroker....
Post by Cummins90 »
A SBEC2 to JTEC (96-99) conversion harness can be installed then fully tuned with HP tuners. That will leave you room to grow if you decide you want to add forced induction.
vernors
Post by vernors »
Thanks, I'll check into this option.
old_man
Vehicle Year: 1985
Post by old_man »
I'm looking at Holley Bypass Fuel Pressure Regulator Kits 12-886KIT. Should work nicely. It tracks the vacuum/boost. I am working on an easy way to adapt it to the Renix fuel rail. I may just end up TIG'ing up an adapter or building on a connector to the fuel rail.
Anybody got an extra renix fuel rail to donate to the cause?
