Starting my build
Rob92XJ
Starting my build
Ok today I took a 4.0L piston and pressed it onto a 4.2L rod and put it on my crank when at TDC the piston to deck clearance was about .008" I've been reading that most people and one of my co workers had alot more clearance and had to deck the block. The block I'm using is a 96 NVH block the crank and rods are from a 89 4.2 out of a YJ. Has anyone else ran into this? I'm dropping everything off at the machine shop tomorrow since my XJ's engine blew lastnight.
rradford9
- Stroker Displacement: 4.5l
Re: Starting my build
Was this a stock piston that you pressed on or a new one? Sounds to me (and I'm pretty much a newb) like you used the 4.0 rod instead of the 4.2. Is there a casting # on it somewhere?
4.5L Simple Stroker
* 4.2L crank & rods
* H802CP pistons (18cc dish)
* 9.57:1 SCR / 8.28:1 DCR
* 0.050" Quench
* 62mm TB
* Hot Air Intake
* 2.5" Magnaflow cat and Flowmaster 50
* JBA Header
* 4.2L crank & rods
* 0.050" Quench
* 62mm TB
* Hot Air Intake
* JBA Header
He's right. what is the casting number on the rods, and what information on the pistons do you have. That will let us answer your question a lot better.
oletshot
I can't figure out what could have happened. 4.0 rod doesn't explain it either. With 4.0 rod being a 1/4" longer than the 4.2 rod, if he accidentally put the 4.0 piston (no matter what make it is stock or aftermarket) onto a 4.0 rod instead of the 4.2 rod, when he connects it to the 4.2 crank it's going to come out the top. Otherwise we would all be doing this and we would much better quench with the poorman's stroker.
Even if you use all 4.0 parts (piston, rod and crank), you don't end up with .008" deck clearance. Best guess I have is reading the measurement incorrectly. Is it possible that it's .080" deck clearance? Bigger mistakes have been made.
If it is .008", and you didn't use any custom parts, there will be a lot of people interested in your combination of parts.
'98 XJ 2-door, '94 YJ.
Did you use bearings?
Rob92XJ
OK I left one 4.0L rod and piston together, installed the 4.2 crank and the piston came out of the block .250", removed piston from rod and installed it on a 4.2L rob had .008". Yes I did use bearings the ones from the 4.0 rod since the ones from the 4.2 were wiped. My co workers stroker had about .250 to the top of the block the only difference is his crank and rods were from a early 80's 4.2 and his block is the original from his 93 YJ. My block is a 96 NVH block and my crank and rods are from a 89 YJ. I had a stock 01 XJ in 2 weeks ago for a misfire due to a burned valve and the pistons were not close to the deck at TDC.
oletshot
I thought when you posted again we would have a logical explanation to this. Unfortunately, above is the only part of your post that adds up. Is it possible your block was decked previously?Rob92XJ wrote:OK I left one 4.0L rod and piston together, installed the 4.2 crank and the piston came out of the block .250",.
Mgardiner1
Definitly not trying to be a smart ass, but do you have main bearings in too? And, what are you using to measure it?Rob92XJ wrote: Yes I did use bearings the ones from the 4.0 rod since the ones from the 4.2 were wiped.
Rob92XJ
As far as I know the block was never decked the engine came out of a friends XJ and the person who owned it before him was a really good customer at the dealership I work for. It is weird from what I had seen on others strokers and from when I worked at a machine shop. I was thinking it may have to do with the NVH block.oletshot wrote:I thought when you posted again we would have a logical explanation to this. Unfortunately, above is the only part of your post that adds up. Is it possible your block was decked previously?Rob92XJ wrote:OK I left one 4.0L rod and piston together, installed the 4.2 crank and the piston came out of the block .250",.
Everything is at the machine shop now, so I don't have the casting numbers handy.
oletshot
From what I remember the new block has a taller deck and would need more material taken off to achieve the deck clearance your finding. Right now, I'm stumped.
Rob92XJ
Yes the main bearings were in too the ones from the 4.0L block, not the 4.2LMgardiner1 wrote:Definitly not trying to be a smart ass, but do you have main bearings in too? And, what are you using to measure it?Rob92XJ wrote: Yes I did use bearings the ones from the 4.0 rod since the ones from the 4.2 were wiped.
What I'm checking it with is this
http://www.handsontools.com/zoomify.asp ... 781123.jpg
My friend and co worker even said his pistons were alot further down the bore then mine are.
Rob92XJ
Same here I posted this to see if anyone else ran into this. But I'm not complaining about it, just weird.oletshot wrote:From what I remember the new block has a taller deck and would need more material taken off to achieve the deck clearance your finding. Right now, I'm stumped.
Maybe I missed it, but what pistons are you using? Possible different compression height than usual?
Rob92XJ
The piston I had pressed onto the 4.2L rod was a bone stock 4.0L piston out of the block. I don't have my new pistons in hand the machine shop is ordering them for me.SilverXJ wrote:Maybe I missed it, but what pistons are you using? Possible different compression height than usual?
Don't the OE pistons have the tallest pin height of all the 4.0 pistons?Rob92XJ wrote:SilverXJ wrote:The piston I had pressed onto the 4.2L rod was a bone stock 4.0L piston out of the block. I don't have my new pistons in hand the machine shop is ordering them for me.
