Pump fuel Question
Bubblhead
Pump fuel Question
Post by Bubblhead »
OK, worlds dumbest question here. Which compression ratio do you go by to determine what octane fuel you may need? Is it the static or dynamic? I have seen numerous references to 8:1 DCR or lower to run pump fuel, but others showing I need race fuel @ 9.5 or higher. The setup I am putting together puts me at 9.6 SCR and 8:03 DCR. Guessing I probably will be good?
Randy Bobandi
Re: Pump fuel Question
Post by Randy Bobandi »
You should be fine for 91 octane, maybe 89. Of course you would start with 93 and see how efficient the fuel is burning. 91 octane typically requires a dynamic compression under 9.0:1.
Randy Bobandi wrote: February 9th, 2022, 9:05 pm You should be fine for 91 octane, maybe 89. Of course you would start with 93 and see how efficient the fuel is burning. 91 octane typically requires a dynamic compression under 9.0:1.
Agree,
Only thing that I would add is a piston dish that has a reverse mirror image of the combustion chamber (same as a stock 4.0 piston) as opposed to a full circular dish benefits from a minimum/tight quench.
I’ve seen guys running the stock 12cc cast 4.0 piston with the shorter 258 rod combo with the piston .025-.030ish negative deck and struggle to run on premium gas with a 9.5:1 static compression ratio, where a piston .035 piston to head clearance (including head gasket thickness) can run s higher static compression ratio of 9.8:1 with the same octane fuel.
Randy Bobandi
Russ Pottenger wrote: February 9th, 2022, 9:53 pm
Exactly. Compression ratio is irrelevant if the combustion chambers are not designed properly. The hot spots in the poorly designed chambers will be the limiting factor.
