Mopar efi v belt harmonic balancer on a 4.2 long snout crank will it fit a 1991 4.0
BillyC
- Vehicle Model: Yj
I have a 1988 jeep yj 4.2L that I have installed a 4.0 head and mopar efi setup on using the v belt front trigger harmonic balancer. The engine is long past needing reworked. The block is a wide block with 1/2 inch head bolts. I used a Detroit red gasket and did not seal off any of the cooling ports in the head but have not had any coolant leaks. I have 2 stroker kits with long snout cranks but I sold one of the Jeeps in the cash for clunker deal and lost my 4.0 block I had for my swap due to the person in possession of the block passing away. My jeep is stored in Southern KY, so I was looking to do a quick swap. Would a 4.0 short block work with the short snout crankshaft and v belt Setup? I would like to keep my v belt 1 wire alternater and Saginaw power steering pump.
- IH 392
Re: Mopar efi v belt harmonic balancer on a 4.2 long snout crank will it fit a 1991 4.0
I don't see why it wouldn't work?, make sure the bolt is torqued with a good slobber of red LocTite.
