gearing for stroker
Andre_ITALY
Learning to use the board
Vehicle Model: TJ 4.0
gearing for stroker
Post by Andre_ITALY »
Hi, I'm currently 35 " km3 with 4.86 crown and pinion (currie 9 ") in my Tj 1997 m / t. With a basic stroker I could use 4.10, to improve comfort on the highway at around 80mph? or in the mountains and off-road will it be worse than now with 4.0? thank you
Vehicle Make: Jeep XJ
Re: gearing for stroker
With a combination of a torquey 4.6 stroker and 35" tires, the 4.10 axle gears would be just about right.
Brianj5600
Vehicle Year: 2004
Post by Brianj5600 »
Andre_ITALY wrote: ↑August 28th, 2022, 12:15 am Hi, I'm currently 35 " km3 with 4.86 crown and pinion (currie 9 ") in my Tj 1997 m / t. With a basic stroker I could use 4.10, to improve comfort on the highway at around 80mph? or in the mountains and off-road will it be worse than now with 4.0? thank you
This is a good gear calculator for picking gears.
http://www.grimmjeeper.com/gears.html
