Hey Y'all! New to the forum.
So, I don't see a lot of info regarding a 4.5 build. Is that kinda useless to date or is 4.6 just the way to go?
I've got an 01 that needs rebuilding and am looking to stroke it out.
I had plans on a 4.2 crank and rods with standard bore pistons along with everything else involved for a 4.5. Or should I just go with the 4.6?
Thanks!!
4.5 or 4.6
PB609
- Vehicle Year: 2001
- Strong Poster
Re: 4.5 or 4.6
Unless you’re planning to rebuild a Briggs & Stratton lawnmower engine, or your John Deere tractor engine I would never rebuild a engine with a standard bore if there was ever a consideration of a upgrade in performance
My .02
My .02
Re: 4.5 or 4.6
I wouldn't risk keeping a standard bore size on a 22 year old block where the roundness and taper of the cylinders may be outside factory tolerances. A +0.020" overbore (3.895" bore) is the minimum required and that, combined with a 3.895" stroke, would make the engine perfectly square with a displacement of 4563cc.PB609 wrote: ↑January 19th, 2023, 12:14 pm Hey Y'all! New to the forum.
Thanks!!
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Semrush [Bot] and 1 guest
