Hi Guys.
I have a FT450 that I am configuring in a Jeep 242 4.7 engine with Coilrack and OEM Crank and Cam Sensor
I cant find information on the specific setup of the Crank and Cam sensor in the FT Manager.
I just need to know what specs should I use in the configuration. Would it be possible for you to point me in the right direction?
Thanks,
Leo.
Ft450 on 4.7 Stroker
lcolina
- Learning to use the board
- Vehicle Year: 1981
- Vehicle Model: CJ7
Randy Bobandi
Re: Ft450 on 4.7 Stroker
For the crank signal, I don't think FuelTech has the OE Jeep crank pattern preconfigured. Best options are; install a trigger wheel, modify the damper or buy an already modified damper.
For the Cam Sync, the OE unit should work just fine as a half moon, hall effect, falling edge.
lcolina
Understood. Thank you!
