High nox on new stroker 4.6
Tonyt22
Vehicle Year: 1993
Post by Tonyt22 »
So I finished my stroker 93 block with 98 head 24lb injectors
All new sensors ,battery, temp sensor relocated to t stat housing ,
.has been running great no check engine lights power all thur the rpm range .
Only problem I'm having is high nox so failing smog
Thought maybe was a issue with a exhaust leak at the flange but fixed it and replaced my cat and still failed thinking might be a fuel issue ?
My scr is 9.3
Think a adjustable map would help ?
Is their any standalone ecu that I can run that i could possibly tune as well
Re: High nox on new stroker 4.6
Your results are consistent with an engine that's running lean.
I don't think a MAP adjuster will solve your problem 'cause you'd only be able to enrich the AF mixture at >70% throttle. However raising the fuel pressure with an adjustable fuel pressure regulator would enrich the AF mixture at any throttle opening and reduce your NOx emissions.
Tonyt22
Vehicle Year: 1993
Post by Tonyt22 »
Cheromaniac wrote: September 20th, 2023, 11:41 pm Your results are consistent with an engine that's running lean.
Thanks for the quick reply
Is hesco the only afpr available for a 93 ?
Can't seem to find anyone else
Would a fixed pressure regulator be good enough like
PR211,
PR209 they operate at 50 and 55 psi ?
