I installed a new Titan Stroker with new exhaust manifold and new PCV/CCV valves and hoses....so those are not the issue. I have a ton of pressure in the motor and blow by out both openings on the valve cover. The engine runs fine as far as noise and no smoke but the pressure is blowing out my rear main seal. I replace the rear seal then drive it and it is fine....then in a few miles it starts leaking and blowing oil out. It loses about 1 quart per 5 miles so it is not drivable.
The exhaust manifold pulls vacuum through all the hoses. I tried making the hole larger in the PCV valve and that slowed the oil drip but then the engine runs bad. This was my indication that it is all pressure related.
Logically you would say it is an issue with the pistons/rings/valves but it is not making any noise and not blowing any smoke. But maybe it could still be that. It is a brand new motor with about 300 miles on it.
Any ideas?
Stroker Too Much Pressure - Rear Main Seal
Bob2001XJ
- Vehicle Year: 2001
Re: Stroker Too Much Pressure - Rear Main Seal
I think you meant the intake manifold, not the exhaust, pulling vacuum. I suggest:
1. Check the idle vacuum.
2. Perform compression and leak down tests.
There's a chance the piston rings haven't seated properly causing excessive blowby.
2grimjim
- Vehicle Year: 2006
- Vehicle Model: LJ
Yeah, you need to do some diagnostics. Do a compression check and a leakdown check. Sounds like something was assembled incorrectly.
