Hey guys, so this has been a long process of building my stroker in spare time. I am getting down to ordering fuel injectors and want to get some thoughts.
258 crank new
4.0 rods
Icon 944 forged pistons +.030
Hastings rings gapped to the big side of towing and small side of forced induction but within both windows
Stock cam
Felpro gasket kit
I was looking at my injectors 01 grand Cherokee they are showing 22.5 Lbs/hr and the ones on the recipe list are showing between 22.8 and 23 lbs/he is this enough increase?
Also I was looking at adding a turbo maybe not decided one way or the other yet thought would get the stroker running first. I saw newcomer has big plenum air intakes and recommends 24 lb min and 35 is more preferred. Thought on any of this?
Maybe the turbo is over the top. Thought it would be a good way to run a stock cam and make more power I could be in left field….
4.6 stroker fuel injectors?????
jason_alex_2009
- Learning to use the board
- Stroker Displacement: 4.6?
- Vehicle Year: 2001
- Vehicle Model: Wj
jason_alex_2009
- Vehicle Model: Wj
Re: 4.6 stroker fuel injectors?????
Here are the injectors I am looking at just dosnt look like these are enough to support the higher hp wanted to get some of your thoughts. Thanks in advance.
Bosch 0280155703 shows 23 # Hr at 3bar (recommend for modified poor man stroker) or calling out around 250 hp ish
https://www.injectorplanet.com/products ... er-5277739
Bosch 0280155784 also show 23 # hour at 3 bars (Medium buck stoker) and shows 300 hp ish on dinos
https://www.injectorplanet.com/products ... 1159050458
here is the factory injector showing 22.5# hour at 3 bars 04854181
https://www.injectorplanet.com/products ... 6862&_ss=r
jason_alex_2009
- Vehicle Model: Wj
jason_alex_2009 wrote: ↑August 12th, 2024, 8:25 pm Here are the injectors I am looking at just dosnt look like these are enough to support the higher hp wanted to get some of your thoughts. Thanks in advance.
Just found this on the forum
One of my favorite guys posted it- Cheromaniac
Bosch 0280155712 19.4lb/hr @ 43.5psi
Bosch 0280155703 22.7lb/hr @ 43.5psi
Bosch 0280155715 23.7lb/hr @ 43.5psi
Bosch 0280155849 24.5lb/hr @ 43.5psi (same as Ford XF1E-A5B)
Bosch 0280155784 26.3lb/hr @ 43.5psi
I like the idea of the 23.7-24.5 injectors want to get your input.
Hi.jason_alex_2009 wrote: ↑August 12th, 2024, 10:37 pmJust found this on the forum
For our straight six stroker engines, my rule of thumb for the injector flow in lb/hr at the operating fuel pressure is estimated crank HP divided by 10.
e.g. If your estimate is 240hp at crank, you need injectors that flow 24lb/hr. If the fuel pressure is 49psi, a set of injectors that flow 22.7lb/hr at 43.5psi would flow 24.1lb/hr at 49psi. Close enough.
jason_alex_2009
- Vehicle Model: Wj
Would it be a big problem to step up one size? Would the computer just tune the injector pulse width down?
I like if I’m going to replace the factory 22.5 to go with something a little more than 22.7 but I could be wrong. Obvious gas washing the cylinders would be bad
You could keep the factory injectors until you've run the stroker and monitored the A:F ratios.
