Hello, I have a question. The new scat forged connecting rods I received do not have a slot to help lubricate the cam lobes like the oem had. Would it be okay to make a small slot in the center of the bolt to help lubricate?
What do you think about it?
Thanks
Rod scat
Randy Bobandi
Re: Rod scat
Yup, it would be just fine. I actually did a set of scat rods like that. I drilled a small .040" hole straight through the parting line.
The other option, which I had Carillo do for me on my current set of rods, is to machine a groove into the cheek of each rod. Just angled towards the camshaft rather than straight up at the bottom of the piston.
- Strong Poster
Re: Rod scat
On a sidenote, it looks like you have assembly lube on your cam lobe’s similar to if not Red line’s assembly lube.
I would recommend going back to the type of Moly lube that contains blends of ZDDP and EP additives as supplied by the cam manufacturers.
Jeeper26
- Stroker Displacement: 4.6l
- Vehicle Model: TJ
Re: Rod scat
Thank you, do you have a particular brand?
Jeeper26
- Vehicle Model: TJ
Jeeper26
- Vehicle Model: TJ
Re: Rod scat
This is an old photo, I used the redline but I had to completely disassemble it to cut the deck.
The engine is not reassembled.
Would liqui moly lm48 be good for lobe's?
I find the compcam very liquid.
Randy Bobandi
Re: Rod scat
No, that's a thin assembly lube better applied to engine bearings.Jeeper26 wrote: ↑November 25th, 2024, 1:29 pm this is ok? https://www.amazon.ca/Competition-Cams- ... 9EEQB&th=1
I use Cam Shield on the lobes only. It's excellent, and inexpensive. It's thick and clings to everything like anti-seize.
https://www.cam-shield.com/product/cams ... lube-pack/
You can see I applied it here with a paint brush.
Jeeper26
- Vehicle Model: TJ
Re: Rod scat
Thank you, here in Quebec, cam shield is not easy to find. Nobody knows this product. I have easy access to Liqui moly LM 48 which is a moly for camshaft. Do you think this could be suitable? Otherwise, I can have on Amazon, Driven or Redline assembly grease. Redline mentions on their site that their grease is good for cam lobes, what do you think?
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 2 guests
