53020515 block in a ‘01 XJ
Nmsejwaj
Post by Nmsejwaj »
I found a smoking deal on a 98 ZJ block that I would like to use in my 2001 XJ.
It looks like there is an issue with the oil filter position possibly interfering with the motor mounts and the oil pressure sensor being in a different location.
Are there any other issues I need to be aware of?
Re: 53020515 block in a ‘01 XJ
Check if the motor mount bolt bosses on the block match your motor mount brackets. Otherwise you'll either have to buy new ones from Brown Dog Offroad or have a pair custom made.
75SV!
Post by 75SV! »
The ZJ block should be the same as an XJ's block. Its the '99 and up WJ block that is different.
LJBean
Vehicle Year: 2004
Vehicle Model: LJ
Post by LJBean »
Here's a source of block interchangeability:
https://wranglertjforum.com/threads/4-0 ... ity.16801/
Users browsing this forum: Bing [Bot], Semrush [Bot] and 2 guests
