4.2 with 3.8 crank
Plaisanced
Stroker Displacement: 4.8
Vehicle Year: 1979
Vehicle Model: Cj7
4.2 with 3.8 crank
Post by Plaisanced »
Pulled my engine apart and was shocked it has 4.0 length rods and 3.8 crank it’s bored .030 what would the reason to put this combination together. The root cause of tear down was #2 cylinder had a diffrent sound and it had a 4.2 rod so a good 3/8inch below head deck
Vehicle Make: Jeep XJ
Re: 4.2 with 3.8 crank
Evidently someone attempted to build a 4.1L mini-stroker (4121cc to be exact) using the 232 crankshaft, except that they should have used 4.0L rods in all of the cylinders with pistons that have a compression height of ~1.58".
Plaisanced wrote: ↑December 17th, 2024, 11:03 am Pulled my engine apart and was shocked it has 4.0 length rods and 3.8 crank it’s bored .030 what would the reason to put this combination together. The root cause of tear down was #2 cylinder had a diffrent sound and it had a 4.2 rod so a good 3/8inch below head deck
good gosh! How does someone screw up that bad...sheez!
Plaisanced
Vehicle Year: 1979
Vehicle Model: Cj7
I think the previous owner purchased a 4.2 rod after possibly bending one the jeep was used as a mud bog racer and motor sucked in water so they just ordered a 4.2 rod for it and never paid attention to casting numbers on it.
Plaisanced
Vehicle Year: 1979
Vehicle Model: Cj7
Unbelievable!
