Hi everyone
I've milled the cylinder head and looking for Rocker Arm Shims that is suitable for our jeeps, since both Crane and Hesco shims are discontinued, what folks now are using?
Rocker Arm Shims
Sniper1st
- Stroker Displacement: 4.8
- Vehicle Model: XJ
- Strong Poster
Re: Rocker Arm Shims
I’ve used shim kits for a late 302 Ford
Sniper1st
- Vehicle Model: XJ
Thanks @Russ for your feedback, I found those shims are they suitable for our engines?
https://aeroflowperformance.com/af95-90 ... ridge-shim
Dimensions of Each Shim
Outside Diameter: 14.25mm
Inside Diameter: 8.20mm
Thickessof Thin Shim: 1/64" (0.50mm)
Thickness of Thick Shim:3/64" (1.00mm)
- Strong Poster
I don’t see any reason why they wouldn’t work.
